Old 08-25-2011, 03:29 AM
adnanahmad adnanahmad is offline
adnanahmad is on a distinguished road
this is the procedure to change the paramets
SYSTEM PASSWORD ACCESS PROCEDURE FOR SOFTWARE VERSIONS 2.0/2.2/2.21/2.31/2.32/2.42D
1.- POWER ON THE MACHINE.
2.- PRESS MON/MENU BUTTON.
3.- PRESS ESC BUTTON.
4.- PRESS F5 BUTTON ( PARA )
YOUR SCREEN WILL DISPLAY THE G53~G59 COORDINATES AND THE STATUS MENU BAR
ON THE LOWER LEFT SIDE OF THE SCREEN WILL BE HIGHLIGHTED.
5.- PRESS THE CURSOR ARROW BUTTON TO THE LEFT <.
THE STATUS MENU BAR WILL NO LONGER BE HIGHLIGHTED
THE EMPTY BAR ON THE RIGHT SIDE WILL BE THE ONE HIGHLIGHTED.
6.- PRESS THE CURSOR ARROW BUTTON DOWN.
THERE WILL BE NO MENU BARS OR ANYTHING ELSE ON THE SCREEN HIGHLIGHTED.
7.- PRESS THE INPUT BUTTON.
AT THIS TIME A DIALOG BOX WILL APPEAR SHOWING A STRING OF 12 CHARACTERS.
NOTE : STEP #7 WILL SHOW YOU THE STRING OF 12 CHARACTERS.
PLEASE LET US KNOW THIS NUMBERS THEN WE CAN PROVIDE THE RELEASE NUMBER
TO GET RIDD OFF THE E435 ALARM.THIS ONLY APPLIES TO THE VERSION 2.31
7.- PRESS THE LETTER F BUTTON FOUR TIMES AND THEN THE FOUR NUMBERS FROM THE DIALOG BOX
e.g.:THE DIALOG BOX WILL HAVE THE TOTAL OF 12 CHARACTERS.TAKE THE
FOUR NUMBERS AFTER THE FIRST TWO DIGITS. FOR EXAMPLE.: QX1014XXXXXX
THEN THE EIGHT DIGIT PASSWORD WILL BE:FFFF1014 THIS IS ONLY AN EXAMPLE.
THE ACTUAL NUMBERS ON YOUR CONTROLLER WILL BE DIFFERENT.
PLEASE MAKE SURE YOU PRESS THE BUTTONS, OTHERWISE YOU WILL HAVE TO
PRESS THE INPUT BUTTON AND START AGAIN.
ONCE YOU HAVE ENTERED THE PASSWORD.GO TO THE NEXT STEP ( 8 )
8.-PRESS THE INPUT BUTTON.,IF THE EIGHT DIGIT PASSWORD HAS BEEN ENTERED
CORRECTLY THE SCREEN WILL CHANGE AND GO TO THE SYSTEM PARAMETER PAGE 1/3
THIS WILL ALLOW YOU TO MAKE ALL NECESSARY MODIFICATIONS
OR CHANGES TO THE 4M SYSTEM PARAMETERS.
PLEASE WRITE DOWN OR RECORD THE OLD PARAMETERS BEFORE YOU MAKE ANY CHANGES
JUST IN CASE YOU NEED TO GET THE MACHINE BACK TO THE WAY IT WAS.!!!!!!!!!!!
