You guys are making this to difficult.
Take a hand grinder (dremel whatever) and grind the case off (carefully (of course)) it is about .050 deep (We usually just grind a flat, nothing fancy) and then you can centerdrill and drill with good grade standard tooling.
Nobody will see your hand ground bit when it is mounted on the T-rail.
