Old 08-18-2011, 02:12 PM
dertsap's Avatar
dertsap dertsap is offline
Gold Member
dertsap is on a distinguished road
these examples are one of the reasons why I refuse to wear coveralls or shop coats (gave up on the hair after the 80's) . theres a few design flaws that I see as dangerous , the long sleeves for one is a hazzard , even when cuffed they tend to be a bit baggy , also the uniform is somewhat baggy if it is to be anywhere near comfortable . the materials that they are made of are strong enough to nearly lift a truck , so if they get wrapped around a chuck then the only thing that will save a guy is if the machine is gutless and stalls out , otherwise it wont be pretty .
I'm actually surprised that no one (that i've seen) has created an instant kill switch that is similar to the kill on seadoo's and some boat motors , where as if you fall then the power is killed . Its probably not as though people would use such a device because it would probably come with issues of its own but if a guy got sucked into a machine then the damage would be minumized , rather than the machine continuing to twist a guy into a knot
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
