Old 08-18-2005, 05:37 AM
lukaslouw lukaslouw is offline
lukaslouw is on a distinguished road
Originally Posted by miljnor
my dad had one in his garage. It was a nicer one than the harbor freight version. Its probably on the high end of the import drill presses.
Depending on the needed accuracy of your hole you could probably just use the type of drill press without the rack and pinion (although the rack would make it alot easier). I've line holes up after moving the pusher type before. just depends on the kind of accuracy you want.
Yes, most drill presses don't have teh spindle stroke for deep holes and the question with these rack an pinion types is how much horizontal slop there is in the rack and pinion gear.....
Lukas
