Do you have an example of your Gcode file we can see?
Have you made a simple test gcode file yet? Make a large rectangle in Gcode using 4 G01 commands with a feedrate command at the start.
Keep changing the F command and watch the machine each time.
__________________ Thanks
Jeff Davis (HomeCNC)
http://www.homecnc.info
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
