just use the drill press with ger21 sugestion. BUT leave it in the drill press move the adjustable table up (I assume it has one) and use the previously drill 2" depth to line the next 2" drill and go for it. If your drill is long enough you should have to do this 2 times and your done. Of course this isn't the most accurate way to go but hey, you goto work with what you got
