if you go with the jb weld dont try to weld in the round hole take out your dremel and cut in some pockets so it can't twist out. try to cut the pockets in a V. If you do it this way it's not going to matter if it sticks or doesnt it will be locked in.
also if you heat up the jbweld a little with a hair dryer it will flow in better. if you can i would use the 24 hour jb it has a higher psi rating. For a slip agent try petroleum jelly.
good luck |
