Old 08-13-2005, 10:29 PM
murphy625 murphy625 is offline
murphy625 is on a distinguished road
Originally Posted by Geof
If this is a joke it is a poor one.
If it is a serious suggestion you need to review your grasp of good business ethics.
ROLLING ON THE FLOOR LAUGHING MY A$$ OFF....
Yes you can JB weld it.. Take the square peg (the part that has to slip out)and coat it with some vasiline or other type of oil... Let the JB Weld cure while the peg is in the hole or you might muck it up when you pull it out. The petroleum jelly or other oil should stop the JB weld from sticking.
Scruff up the square hole as best you can with some gritty sand paper.. clean everything with acetone .. JB Weld away!!..
It will break again but should extend the life for a while anyhow.. Depending on how much stress is on the square hole, it will either break quick, or may even last longer than the next malfunction..
Good luck!!!
Murphy
