How to control a relay with a PC | | I need help. I'm trying to do some development on a project, and I would like to be able to energize a circuit with a PC or other device that would give me an adjustable and repeatable on/off signal. For example, I may want to turn the circuit on for 1 minute, then off for 5 minutes, or I may want to have the circuit on for 45 minutes then off for 30 minutes, depending on the circumstances.
The on/off will be controlled with a relay. That part I'm comfortable with. What I'm not comfortable with is how to control a PC port from windows to send the on/off signal. I don't care if I use a serial, parallel, or USB port.
Are there any readily available programs to send a signal like this? Or am I gonna have to find someone who is comfortable with C or C++ to help me with this? Any help would be much appreciated.
I'm not dead-set on using a PC to control this, so if there is another method of making a timer that has the needed flexibility, I am all ears.
__________________ My name is Electric Nachos. Sorry to impose, but I am the ocean.
http://www.bryanpryor.com
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
