Old 08-11-2005, 10:36 PM
ViperTX ViperTX is offline
ViperTX is on a distinguished road
Well you could use those steppers to proof your design....then when you have cash...buy some larger steppers....the driver boards would be the same...if you select wisely. I would not directly couple the steppers to the leadscrew....design it so you can change pulley ratios and use timing belts/pulleys.
