Ok
checked the setup yet again this time with with desknc .doc and duh..... I had it all wrong I had the correct pins set but desknc does not use pin assignments it assigns each pin a bit number not sure why? but once the bit numbers where plugged in CORRECTLY it all works again :-) again did I say duh
anyway, thanks for aall the help.
Ray
__________________ Learn from the mistakes of others you can't afford to make them all yourself! |
