Rotating Nut Ball Screw for dual X axis | | I am tring to decide between Ball Screw or Rack and Pinion for the Drives on a 6' X 4' CNC router table.
Accuracy as well as cost is important!
Rack and Pinion seems to be a cheeper option but accuracy is lacking. I have thought of using a 20mm Rolled Screw fixed at either end and then rotating the nut to provide the motion. Thus whip should not be a problem.
Is this a sound approach to this problem? |
