Old 07-04-2011, 06:47 AM
essele essele is offline
essele is on a distinguished road
I put a solution together in Perl ... it's still in the prototype stages, but theres no reason why you shouldn't be able to make it work in Windows.
I've only tested with EMC, so obviously you'll need to carefully test with Mach3 otherwise many broken bits will result.
Zen Toolworks LLC • View topic - SOLVED ... holding PCB's flat, or not!
Regards,
Lee.
