Most people that have Fadals mount the indexer on the right side of the table as the plug for the cable is on that side. If you mount it on the left side of the table it will seemingly rotate in the opposite direction (not really). May not help in your situation though. Do you have programs from some other machine you want to run on this Fadal? Minor program edits will change the program, unless you have a ton of index blocks.
Alloyspec |
