I've run lots of different motors with AB 2098-dsd-xxx (Ultra3000) drives with no issues. The Ultra3000 drives can be setup using Ultraware and they autotune to the motor and whatnot. Its really easy to setup. If you can use Ultraware on your drives, I don't think you would have any problems getting them to run. Also you need to make sure the drive accepts the type of drive signal your controller puts out (most likely step/dir from mach3 or similar.
If you already have the motor and the drive, hook them up and give it a shot.
Matt |
