Thanks for the help. I can now successfully download from the CNC to the PC. I am having trouble flowing info in reverse. At CNC, I am in EDIT mode; at the keypad enter "O0999" [0999 is program name]; press INPUT; LSK flashes at the bottom right of the display; from the PC running EditCNC I send the program named "0999". As soon as SEND is entered on PC the controller registers an 085 error which according to the list of codes I have indicates a data overrun or baud rate error. Both CNC and PC are set at 4800 bps and 2 stop bits. Parity is Even, flow control Off, data bits 7
Any suggestions?? |
