I want to wrap a graphic skin to the same curve as a mold cavity skin. I do not want to join the two skins. I want to machine the graphic as a separate operation after the cavity is milled.
Can I extrude the graphic after I have used project a curve? Or should I make the graphic skin an extruded solid and use a solid editing tool like "difference" and use the cavity skin to slice the graphic solid at two different elevations? |
