Old 08-03-2005, 12:03 PM
Barker806 Barker806 is offline
Barker806 is on a distinguished road
Originally Posted by CNCadmin
Thanks Art for you time,
I'm using the z signal because that is the only one that works, setting it on the spindle pins, does nothing. Even when I press the spindle button the laser will not turn on, I'm sure I'm doing something wrong, but I can figure it out. In the set-up page I select the spindle control and PWM, than I set the pin number that I have the control contented to on my break out board. Manually I press the spindle control button and nothing happens.
There are some settings that you have to set on the ports and pins page. If you would like to send me your XML I will have a look at it and send it back to you
Brian
