Originally Posted by georgebarr Is there a way in Powermill to specifying some gcode once and reusing it many times and each time modifying just the X & Y positions? I have gcode for thread millling used to create 1 thread on 1 hole. But, I want to resuse the same code for many holes which means reusing code and changing just the X & Y positions. Any way to do this? |
Hi! Have you solved your problem yet? I solved this problem for myself by doing a little bit of manual programming in the program generated by Powermill.
