  #11
Old 08-01-2005, 02:25 PM
lerman lerman is offline
Gold Member
lerman is on a distinguished road
My reference for o-rings is Parker O-rings: http://www.parker.com/o-ring/Literature/00-5700.pdf
Parker shows precisely the geometry that I'm using.
My application is for low pressure (1 PSI or so), where a screw on cap will be removed once every week or so.
So far, if the lots of coolant solution doesn't work, the mill an 1/8 inch starting groove first suggestion will be my next try. I'll probably mill down a helical ramp taking about an inch to travel to the full .112 depth. I'm reasonably certain that will work, since the original dovetail did fine except at the entry.
Ken
Kenneth Lerman
55 Main Street
Newtown, CT 06470
