Old 07-31-2005, 05:20 PM
colin1544 colin1544 is offline
colin1544 is on a distinguished road
Ajax Retrofit
Originally Posted by AAA
At present I've been investigating purchasing a second hand CNC knee or bed mill for retrofitting with an Ajax control setup, and have been trying to educate myself on the different machines out there.
One of the likely candidates is the Bridgeport Boss machines. Main problem is there really doesn't seem to be much in the way of useful information out there on these machines - here or elsewhere on the web.
Boss 1-7 use steppers, and 8-12 use servo motors. What's the other differences between all the Boss models? Is it just controllers?
What's the difference between Series I and Series II machines.
Some sort of matrix showing the different models and features would be most useful.
Any help appreciated.
thanks
Mike
Hello Mike
I have a series I CNC which was origonally fitted with a Boss 5 control the ajax cnc system which you refer to is a kit complete with 3 x 29 lbs ins dc motors with shaft encoders built in, a card which fits into the PCI or ISA slot of a PC and a 3 axis servo control board also comes with intercon interactive control software with different options to suit your requirement.
On my system I have removed all of the origonal electrics except for the 240 volt - 110 volt transformer which I used so that I can run my machine on single phase also using a VFD single to three phase inverter for the spindle motor and using the speed control unit from Ajax gives me programmable speed control from the software. Upto now I have been very pleased with upgrade and would reccomend it to anyone considering a similar retrofit be it on a series I or series II I had one of these previously some years ago before the advent of retrofits were freely available, wish I still had it as well as the series I which would be just the same to convert.
If you email Jesse at Ajax controls he is very helpful also the dvd on programming the machine is very good.
