Is a router only good for routing? | | I have 4 different drill bit sizes with all different shanks and two end mills to cut out counters. Most drill bits are rated at 2800-8000 rpms, router only go down to 8000 and I don’t want to buy collets for every drill size.
What do you do when you want to drill?
If a drill or endmill is rated at an rpm what will happen if you use it at a higher rpm?
What do you do if you have a CNC that uses a porter router to drill/Mill? |
