I think it depends on the control. But if you issue a command like
G01 X12 A360 F60, both the X and A should get to there destinations at the same time. Whether it takes 12 seconds or 6 minutes, you'll have to check. Using the axis as linear is something I've seen on the TurboCNC group to solve this type of problem.
__________________ Gerry
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
