I think you could use 2 different size timing pulleys (If Im picturing this setup correctly). Motor to "pinion shaft and Pinion shaft to Drive belt.
The ratio of the belts could give you your reduction.
__________________ Wee aim to please ... You aim to ... PLEASE. |
