Old 07-22-2005, 07:06 PM
JavaDog's Avatar
JavaDog JavaDog is offline
JavaDog is on a distinguished road
Originally Posted by psychomill
In 1/4" you might be able to get away with buying whats called a "S&D" drill (Silver and Deming). For a 1", it should fit your chuck. You don't have a lot of power so just take it easy on it. I've drilled 1" + sized holes on a cheaper and smaller drill press and got by with it.
The 2" hole is tough for trying to drill though. Instead, I use a hole saw. You're only going through 1/4 plate so it should be no problem. Just peck at it with some cutting fluid brushed on.
I've seen the Silver and Deming sets...what exactly are they that differs from normal drill bits?
Holes saws tend to make really sloppy holes though - but that why there is sandpaper! I know I have a decent set in that size...
Originally Posted by ViperTX
Well you could use a bi-metal hole saw, or you could chuck up a boring head on your drill press.
Boring head? Isn't that what happens after you get married?
Seriously though, what is a boring head? I've seen them in catalogs, but I don't know how they work...
Check Out My Build-Log: http://www.cnczone.com/forums/showthread.php?t=6452
