Old 07-21-2005, 09:02 PM
anoel's Avatar
anoel anoel is offline
anoel is on a distinguished road
I don't really see a point in it... there's no real reason to use both the fence and the miter slot at the same time. When you use the fence you typically use a push block and/or feather boards. And when you use the miter slot you typically back the fence off or remove it so the offcut of the work piece clears it.
Nathan
