Old 07-20-2005, 10:15 AM
nikolatesla20 nikolatesla20 is offline
nikolatesla20 is on a distinguished road
Stepper motor speeds
Hi, Cnc newbie here
I posted in another forum about some steppers I have and I remarked about the fact that I didn't think I would be able to go very fast. Can someone double check my math?
I have 400 step/rev motors. I'm not sure what their torque is. They are only rated for .4 amps. I plan on making a foam cutter with them, so they don't need to move super fast anyway.
If I mate these up with a 1/4 - 20 threaded SS rod, you get 20 rev/ inch on the rod. So 20 revs * 400 steps / rev = 8000 steps / inch.
I'm using a UCN5804B chip on each motor to drive it, using 12V and a 22ohm resistor in series with the motor (motor is 16.5 ohms) to get around .300 amps. I realize that is probably pretty butt weak for a CNC? (Although as I mentioned I am going to be doing very very lightweight work. C'mon a hotwire foam cutter really has no mechanical load!)
I'm currently experimenting with KCam software, and I can't seem to really go faster than 1in/min. If I go faster it seems like the motors start to miss steps.
Could it be the software (talking thru XP maybe it can't keep the pulses up correctly) or do I just need bigger motors to go faster...
The reason being is if I use a larger lead screw, like instead of 20th/in if I could get like 13/in I could go faster and the motor requires less steps/inch so it doesn't have to be driven as fast. Yeah accuracy per step decreases, but 8000 steps/in comes to .000125 inch per step, I really don't need that much "accuracy" anyway...
And so KCam driving at 1in/min would be 20rpm.. to go up to 10in/min it would be 200rpm and would be 1333 steps/sec..wow can't believe motors that can take that.
I'm pretty sure my math is right.
-niko
