I believe SYS 102.1 is the latest OS. 96.1 B4-3 is a good OS. I requeasted to have two 1998 machines OS down graded to 96.1 B4-3 do problem with OS (version?) that came with those two machines.
You can run JOG in Auto mode if you press Feed Hold. And then continue at a new location or go back.
Is the problem of pressing the Manual key to go to MDI only on one of the machines? Or the same on all of them?
The typical problem, if any I have, is pressing the Manual key while the machine is stopped in single block mode and having the auto mode quit out to the command mode.
Anyway the Manual key from Auto mode (stopped motion) must be pressed twice to get to MDI. (Stopped motion ether by single block or feed hold.)
__________________ Safety - Quality - Production. |
