Thread: Threading MDF
Old 07-19-2005, 08:26 AM
Me2 Me2 is offline
Me2 is on a distinguished road
Threading MDF
Hello all,
I'm currently getting all the materials together to finally start my own CNC wood router. The drives are completed and the motors spin in tune to the Gcodes I've put into Mach2 created from some solid modeling.
I'm basing the design on Joe's arrangement and building out of MDF. With this arrangement the threads are cut direct into the MDF to attach the various assemblies. I tried tapping the threads in the same way but found even the slightest bit of over tension resulted in the threads pulling out rendering them useless. I'm not sure if anyone else has tried to overcome this problem but I experimented with various ways to strengthen the threads and found coating them in Super Glue made all the difference. The MDF fibers when cut act like a sponge. The Super Glue being water like is soaked up very easily and when dried gives the thread and extremely hard face. The Super Glue that has wicked into the fibers creates a hard plug around the threads making them hard to pull out. To give you some idea of how strong the thread becomes through this process, the bolt when tightened against a washer is able to pull the washer into the surface deforming the MDF. Just going by feel I would say the applied torque between the treated and untreated thread would be almost doubled.
Cam
