Originally Posted by Geof MiniMill 2000, MiniMill 2001, SuperMiniMill 2002, SuperMiniMill 2003, SuperMiniMill 2004. The last two Supers have the extended Z clearance, 4th axis and are fitted with HRT210 rotary tables. The 2004 Super had some problems with the tool changer motors that was due to a defect in the motors not exactly the fault of Haas. The motors were all replaced under warranty and so far the problem has not occurred again. |
Hass told me the extended Z was just a head riser & still only had 10" Z.
Cause I had that on my order. 14" Z would be nice on the mini mills.
Mine seems to run fine except for an oiling deal. If I let it set for a week I have to pump the oiler by hand or it will error out. Must be a very fine air leak. No big deal because I don't run it much.
