Old 07-17-2005, 02:55 PM
haysys haysys is offline
haysys is on a distinguished road
Sharp edges
... While you are at this stage with everything apart take a moment to remove those razor sharp edges with a fine mill file or india oil stone - don't get carried away with large radiuses, just break the sharp edge so it can't cut you or someone else.
This should clear up some of the confusion and common mistakes made lapping ways.
If you decide to lap your ways, you are responsible for the results. No one at CNC Zone including myself, the site owner and site provider are responsible for the results.
Mike
Mike, thanks for the input. While I followed Aaron's instructions quite closely, it is certainly possible that I over-did the lapping, though I truly doubt that I removed enough material to cause the current condition. Rather I suspect the Asian folks responsible for that particular function missed the target. But who knows for sure?? Not me.
I would add one further comment on the "sharp corners" point. It is important to leave the sharp corners on the ends of the sliding way edge untouched. Reason being is to have that sharp corner plough all chips from the way surface. A less-than-sharp corner can allow small chips to be "ridden over" and cause binding and/or wear.
