Well, what I use on my Haas is a command to move in the machine coordinate system, which is called the G53 coordinate system.
G00 G53 X20.0
This will bring the table to mid travel if it has a 40" stroke.
Take care that the machine is running in the proper work offset after using this command, in case they are all cancelled by the prescence of the G53.
__________________ First you get good, then you get fast. Then grouchiness sets in.
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
