  #10
Old 07-15-2005, 10:18 PM
ChrisJ ChrisJ is offline
*Registered User*
ChrisJ is on a distinguished road
That Duraplus is rated at 185 PSI at 73F. What is the pressure rating of the pipe at 200F? The air leaving the compressor when you compress the air to 100 PSI or better is going to be hot.
Did they use the Duraplus on the distribution only, and used something else close to the source?
Sorry there Dieguy, you already had the link attached would referenced the ANSI/ASME standard. I should have looked at your links first.
Chris
