Thread: Z AXIS ERROR
Old 03-25-2011, 07:05 AM
JeffsJeep04 JeffsJeep04 is offline
JeffsJeep04 is on a distinguished road
Originally Posted by ZZZZ View Post
The Home switch and the Overtravel switches are located under the way covers, screwed to aluminum angles, mounted under the edges of the opening for the ballscrew.
The encoder is located inside the end cover on the motor.
What are the 'Y axis issues' you are having?
The typical error is (if I remember right) a "408: Y Axis Excess error". The lead screw can be freely rotated by hand, and if I hold the reset button, I can get Y to move ~.100. It's nearly all the way back in the negative direction, and if I move it more negative I get a servo error.
