Originally Posted by bigb8766 I use Compact 2 every day. It is still powerful software. Excellent for part families. It hasn't been supported in a number of years, and will not work with windows 7. Needless to say, it is near extinction, since it no longer has support. |
Yes almost extinct, but still more versatile than ANY new breed of software. Why no one has rewritten this with a more modern front end and visuals eg 3d backplotting etc is totally beyond me. We are now using a combination of macro CII programs and a modern software to do the odd stuff. But, if i had to do a standard family parts job, even with a high end parametric modelling system there is no way it could be done as quick. Some of our std parts which are quite involved can be fully programmed in less than 20mins using parameters. Do this on modern system even with a model would take way longer and outputs more g-code.
What version you use? I saw in an earlier post that Compact II has no toolpath display...Ours does. Also is your key locked to the network card? I have seen there is now some software you can get that can spoof Mac Address of netcard maybe this is a way to keep it alive if card fails. That is if its legal.
Keith.
