Thread: Z AXIS ERROR
Old 03-24-2011, 03:33 PM
JeffsJeep04 JeffsJeep04 is offline
JeffsJeep04 is on a distinguished road
Originally Posted by HSARC View Post
IF YOU HAVE A PARTNER MACHINING CENTER (ABOUT 1995) WIRING TO HOMING SWITCHES HAVE INSULATION THAT WILL DISSOLVE ; SHORTS OUT SWITCH SIGNAL,WILL AUTOMATICALY FEED WRONG DIRECTION UNTIL IT HITS LIMIT SWITCH. ALSO ENCODERS ARE NOT WELL SEALED, TAKE COVER OFF AND CAREFULLY CLEAN GLASS. (ONE WAY TO CHECK ENCODER UNHOOK FROM BALL SCREW, TURN ENCODER SHAFT MOTOR SHOULD FOLLOW.)
Hate to bump a two year old thread, but I just started a new job and we have a 1999 Partner and it's having Y axis issues. Could you go into more detail about where to find the encoder and homing switches? I have the way covers removed and the lead screw turns freely. I switched the cabling on the drives between X and Y and it still trips out on Y, so it's not the driver.
