I can probabally get the ball park, they should have model 2 or 5 or somesuch,I meant does Centroid have a analogue output for 3rd party drives as you might find one of the AMC largest amps will do the trick, if the original motors had tach's on them, you can probabally do without them now as modern amplifiers are run in the Torque mode with the loop closed via the encoder only.
Also, if you obtain amplifiers that need a power supply, unless you are selling them, you could cannabalise the old amplifiers for the power supply, they are parobabally three phase at present, or are you planning on running on 1ph?
__________________ CNC, Mechatronics Integration and Machine Design.
Albert E. |
