Running a program that I have ran on the Fadal, I found that in the corners of a retangular cutout, the corners were not as sharp. The mating part would not fit. Also feeds near or over 30 ipm would not hold size doing small arcs on a small part. The Haas default in zone before the next move is .050. To change this value you ether go into the machine parameter default value setting for this or use a G187 E word to change the value in a program. For my purposes a G61 does the trick. And then return the machine to G64 for drilling and tapping. But all milling operations on the Haas I use G61.
(The Fadal default mode is G9 equivalant to G61. The Fadal G8 is as to the G64. On the Haas Mill G64 milling mode is the default mode. If you want to force the G64 in zone value to be, lets say .010, then the in program code would be on the Haas: G187 E0.01. Again the value on the Haas mill is G187 E0.05 by default.)
__________________ Safety - Quality - Production.
