I am also a mastercam user so i know first hand the toolpaths
will work.
What will you be cutting.from solid? Are you roughing BHT?
You want to use z-level roughing method.
Side milling you use 5-7% step over.
Cutters: It all depends what you want to spend. Obviously
the more you spend the better the tools.
You want tialn and ALtin coated cutters.
Kobelco,Hitachi=the best
Osg,robjack=60-70% price & performance
Fullerton,roundtool=good for rough & semi finish.
If you want to see some sample Videos go to
www.hardmilling.com
If you need it programmed for you we can set you up with
what ever you need. Just tell Dale Steve sent you.
Good luck!!!
