  #11
Old 07-11-2005, 07:30 PM
MetLHead's Avatar
MetLHead MetLHead is offline
Gold Member
MetLHead is on a distinguished road
Andy,
Currently, you will only see program jumps within the same file. Although, it would be nice if NCPlot would recognize when there are multiple programs in the same file, like the one you sent me. Then you could see the jumps to subprograms. There are several ways to accomplish the display of subprograms, I'm just not sure which one to use, if any. I'll definately keep this on the wish list.
The program is fully executed before you see it on the viewport, so you cannot see variables update as the program is stepped. This was something that could be done in the earlier beta's but has since been changed. It's a feature I really miss, so it will probably make it back in.
Your other suggestions are also good ones, and I'll keep them in mind.
If you're having a problem with a program not plotting correctly, please send it to me. Or at least enough of it to demonstrate your problem. This will help me greatly when trying to find it.
Thanks for the feedback,
Scott
