You would probabally need hardware changes as well as software.
If it has one of the well known motion control cards in a PC slot, then you may be ahead in not having to purchase another. Otherwise there are a few PC based systems outhere to consider. Otherwise unless the company is still around with an upgrade then it will require a bit more than just a simple software installation.
I just googled them and I see they still operate out of Calgary, so not far from you.
__________________ CNC, Mechatronics Integration and Machine Design.
Albert E. |
