Old 07-24-2003, 06:29 PM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
Originally posted by cadcam
Mortek , Most of the time Fanuc like to have a diffrent D value so more like T1 H1 G41 D21.
hope this helps just extra things to know.
Cadcam,
I have to kindly disagree with your statment that most Fanuc or fanuc like controls like different number from your tool number.
I use the same offset as the tool number, have for about 15 years, never seen any problem.
You can use a different offset number, if you want to leave extra material, say for a finish pass.
So if you are using tool #1 that is a 1/2 mill, you could set offset #1 to .500 and use offset #21, set at .505 to leave .0025 material for clean up.
