Also an important thing to remember when manually programming G41/G42 is that before your cut, you need to enable the G41/G42 with a move that is at least 1/2 the cutter diameter. This also goes for turning off cutter comp with a G40.
You might get some unexpected results if you try to turn cutter comp on with your first cut.
-JamesBond
__________________ Experience is the name every one gives to their mistakes. |
