Old 04-01-2003, 03:20 PM
balsaman's Avatar
balsaman balsaman is offline
balsaman is on a distinguished road
One thing you can consider is mounting the motor on the axis and turning the nut via a timing belt/pulleys. This nut/pulley would need to be located between two thrust bearings. Then the screw will be installed on the machine in a fixed position (doesn't turn). Now you have eliminated whip, and you have much less mass to turn.
Eric
I wish it wouldn't crash.
