On a large commercial machine, the only reason to slow the feed rate is if the quality of cut is not good enough. On a home built machine, the machine may flex too much at higher speeds, or the router (spindle) may not have enough power.
With melamine faced board, a poor cut will have chipping on the edges. Slowing down will not always correct this. Sometimes you need to use a sharper tool.
__________________ Gerry
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
