These dont come in as surfaces. They are lines and splines.
Are thay actual surfaces in AMD ????
If so the MC help says ......
Use this procedure to read Mechanical Desktop entities. This procedure explodes Mechanical Desktop entities into their component pieces which, when saved as AutoCADŽ entities, can be converted to MC9.
1. Open the drawing in Mechanical Desktop.
2. Click on Modify and then on Explode.
3. Click on the Mechanical Desktop entities you want to convert.
4. Save the file under a different name (with a DWG extension) so that the original file is not overwritten.
5. Convert the file containing the exploded entities.
Note: This same procedure can be used to convert files from other AutoCAD packages that create proxy entities.. |
The only other option is to re-surface in mastercam.
1. Press Alt Z
2. Make Level (#6 Wing Surface) active by clicking on the "6"
3. Turn off all levels except (#2 Wing & #6 Wing Surface)
5. Click OK
4. In the main menu: Create/Surface/Loft/Window
6. Window select all the cross section curves
7. click a search start point (pick the end of the first curve)
A surface will be created that can be toolpathed
CAM
