Keith, There are some bugs in the most recent Fadal post on the website, as on several of the other posts. I do not understand why they do not change these where they will work. I guess the want you to pay their maintenence fee and they will send you a post that works. Go to Cam/Setup/Macro and look at the files and you will see some of the problems if you are familiar with Fadals and Format2. You might open several other posts and look at them to compare. I did have a post that worked well at one time without using any scripts, just the replacement text files. It can be done, you do not have to learn scripting to fix a post the way you want it. You just have to do without all the fill-in the blank boxes, then manually edit the text. In the long run it will pay you to learn a little about scripts though.
Alloyspec |
