When using a compressor from a fridge as a vacuum pump remember to occasionally add several drops of oil into the suction side. Refrigerator systems are a closed loop system where oil and freon circulate together. When you open up the system you loose it all. Use either a synthetic oil like Mobil 1 or if you can find it Texico WF 32.
__________________ If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down. |
