Old 01-16-2011, 04:11 PM
m230042 m230042 is offline
m230042 is on a distinguished road
the plate pro was offered with the d-10 and the burney replicator?
The d-10 had many issues reguarding the controller. Including a modifaction to the control board adding some filter caps. There was also some wireing issues with the power supply connectors to the control board (Green ones) The wires were not stripped back well and intermittent ground conditions existed.
The biggest help is insure the power cable to the controller plug in is clean and well fitting. The angle it is mounted at with the swivel base put a strain on this connector and sometimes looseing it.. The next problem is thermal plasmas. Very noisy electricly.
