Old 06-23-2005, 01:55 PM
mxtras's Avatar
mxtras mxtras is offline
Silver Member
mxtras is on a distinguished road
Concrete is a good dampener, for sure. Low shrink grout is excellent for this kind of thing. If you do it, use a fairly dry mix and compact it with a vibratory settler to remove the air - you can rent one pretty cheap. Intimate contact between the steel and the grout after the grout is cured is essential for best results. It is a good idea to at least clean the surfaces that will contact the cement or grout and if possible, prime. Don't fill when the structure is cold - warm it up and let it 'soak' first. Get the filler material and the structure at about the same temp and keep them there to avoid internal condensation.
Scott
Consistency is a good thing....unless you're consistently an idiot.
